My problem is that, after connecting my Rpi to the home Wifi network, it refuses to connect to the internet. Funny thing is: I am connected to it via ssh. I tried to ping google, but it said:
connect: Network is unreachable
Then I tried to ping google`s IP, but the same thing happened. I tried the method described here but nothing is working. How can I get my pi to connect to the internet?
If this might be any help, here is the output of route -n:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
169.254.0.0     0.0.0.0         255.255.0.0     U     201    0        0 lo
192.168.1.0     0.0.0.0         255.255.255.0   U     303    0        0 wlan0
I had my pi connected to this network before and I have set it to a static IP "192.168.1.23". It used to work but it suddenly broke and hostname -I gives the following output:
192.168.1.23
So everything seems to be correct aside from the fact that I cannot reach everything (literally everything, even localhost is unreachable). And one more thing: I am connected to WiFi via a repeater. Thanks in advance.
PS: My question is not a duplicate of this question. I have searched pi StackExchange but nothing worked.
EDIT:
I used the WiFi management GUI To set the static IP on my Pi.
donjuedo
  • 115
mohamed emad
  • 91
Thanks Guys But I found the answer Everything worked after I reset the configuration in my /etc/network/interfaces to
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
,thanks anyway
mohamed emad
  • 91
I had the same problem using Wi-Fi, I had also to change:
allow-hotplug wlan0
to:
allow-hotplug wlan0
iface wlan0 inet dhcp
Then the internet connection worked
Darth Vader
  • 4,218
  • 47
  • 70
