I'm customizing my minibian distro and now having hard time to set up two network interfaces: wireless (wlan0) and wired (eth0).
I want eth0 to have a static IP (in case I need to connect it to the network using wires), while wlan0 (set up with wpa_supplicant) to have a dhcp address from my wireless router.
/etc/network/interfaces:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 192.168.1.100
netmask 255.255.255.0
gateway 192.168.1.254
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
/etc/wpa_supplicant/wpa_supplicant.conf:
# reading passphrase from stdin
network={
ssid="my_wifi"
#psk="Password"
psk=03632d6ca0734abdb5ae1b889f8028552b196f6f7d40e365ebbef7d8d7ac7fee
The problem: when I connected to my router using cable over eth0, then both my interfaces (wlan0 and eth0) are connected to network - I can ping them both from my other machines.
If I unplug the eth0 in order to have only a wireless connection, then wlan0 also goes down and ping stops response stops.
But if I plug the cable back - I'm getting ping back on both interfaces (eth0 as well as wlan0)
What am I doing wrong?
EDIT:
So here is the interfaces details when the cable is connected:
root@raspberrypi:~# ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:a7:ba:c2
inet addr:192.168.1.100 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:fea7:bac2/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1098 errors:0 dropped:0 overruns:0 frame:0
TX packets:530 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:73489 (71.7 KiB) TX bytes:57234 (55.8 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr b8:27:eb:f2:ef:97
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:fef2:ef97/64 Scope:Link
RX packets:1410 errors:0 dropped:35 overruns:0 frame:0
TX packets:26 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:140549 (137.2 KiB) TX bytes:2792 (2.7 KiB
Ip command output:
root@raspberrypi:~# ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:a7:ba:c2 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.100/24 brd 192.168.1.255 scope global eth0
inet6 fe80::ba27:ebff:fea7:bac2/64 scope link
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:f2:ef:97 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.2/24 brd 192.168.1.255 scope global wlan0
inet6 fe80::ba27:ebff:fef2:ef97/64 scope link
root@raspberrypi:~# ip route
default via 192.168.1.254 dev wlan0
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.100
192.168.1.0/24 dev wlan0 proto kernel scope link src 192.168.1.2
