I'm new to the community, as well as novice in the Pi family. I want to stitch several videos (for example 5). I tried using FFmpeg, but the output was only first input video file.
I was running this code:
ffmpeg -i video1.h264 -i video2.h264 output1.mpg
anonymous2
  • 155
batman_rising
  • 61
You can't specify multiple inputs for FFMPEG like that. You can, however, use the concat option, as described in FFMPEG's documentation. There are different forms depending on whether you're joining files with different codecs or not. It's worth reading all of the documentation - there are more than a few caveats and options in there.
Files with the same codecs:
Create a file mylist.txt with all the files you want to have concatenated in the following form (lines starting with a # are ignored):
# this is a comment
file '/path/to/file1'
file '/path/to/file2'
file '/path/to/file3'
Note that these can be either relative or absolute paths. Then you can stream copy or re-encode your files:
ffmpeg -f concat -safe 0 -i mylist.txt -c copy output
The -safe 0 above is not required if the paths are relative.
Files with different codecs:
ffmpeg -i "concat:input1.mpg|input2.mpg|input3.mpg" -c copy output.mpg  If you have MP4 files, these could be losslessly
concatenated by first transcoding them to mpeg transport streams. With h.264 video and AAC audio, the following can be used:
ffmpeg -i input1.mp4 -c copy -bsf:v h264_mp4toannexb -f mpegts intermediate1.ts
ffmpeg -i input2.mp4 -c copy -bsf:v h264_mp4toannexb -f mpegts intermediate2.ts
ffmpeg -i "concat:intermediate1.ts|intermediate2.ts" -c copy -bsf:a aac_adtstoasc output.mp4
goobering
  • 10,750
  • 40
  • 64
The -i flag just defines an infiles. You need to define what you are going to do with those infiles, rather than simply exporting them into your outfile. In view of that, according to ffmpeg documentation, the best method is to start by creating a file with your video in-files in it. Here's an example (just call the file mylist.txt):
#this is a comment
Then you can run the following command:
...where output is your output filename.
Two more things bear mentioning. Firstly, the -safe 0 option is not required if the paths are relative. Secondly, you are not just doing a straight copy in your command mentioned. In other words, your outfile looks like it is supposed to be a different format than your infiles. Therefore, you will have to add on the appropriate flags for the -c option (codec) to come up with the codecs you are looking for.
anonymous2
  • 155
