I have apache 2.4 on my raspberry pi and need to change DocumentRoot to flash drive folder. But I have 403 Forbidden.
In apache logs:
AH01630: client denied by server configuration: /media/pi/www/html/
and
AH00035: access to /index.html denied (filesystem path '/media/pi/www') because search permissions are missing on a component of the path
I have read article on apache site for this error and make chmod like this, but it still forbidden:
root@raspberrypi:/etc/apache2/sites-available# namei -m /media/root/www/html/index.php
f: /media/root/www/html/index.php
drwxr-xr-x /
drwxr-xr-x media
drwxr-xr-x root
drwxr-xr-x www
drwxr-xr-x html
-rw-r--r-- index.php
Domian config:
<VirtualHost *:80>
<Directory "/media/root/www">
AllowOverride All
Require all granted
</Directory>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request's Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
#ServerName www.example.com
ServerAdmin webmaster@localhost
DocumentRoot /media/root/www/html
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the loglevel for particular
# modules, e.g.
#LogLevel info ssl:warn
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
# For most configuration files from conf-available/, which are
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with "a2disconf".
#Include conf-available/serve-cgi-bin.conf
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
If change to origin /var/www - all works fine.
