I'm using a Raspberry Pi model B (512 MB RAM) with the following touch screen and the latest image of Raspbian. The screen drivers are ok, since I can see the loading screen and the tty. If I plug in a keyboard, all is fine (textual, but fine).
The problem is that the GUI isn't loading. I have configured the automatic GUI and login through raspi-config, I think all the necessary packages have been installed (following this post), but it doesn't work. After the booting information I am stuck with a black screen with a fixed (not blinking) cursor on the top left corner. service lightdm stop brings the cursor blinking, service lightdm start gets it fixed again.
Seems to me that the X server has started correctly but I'm on the wrong virtual terminal; I have tried using chvt on all the terminals from 1 to 12 without success. Log files .xsession-error, LXDE/run.log or Xorg.0.log don't show any error (at least, none I can mark as error), but I can provide them if needed.
I've run out of option, can you help me?
Edit: dmesg|grep fbtft
[   13.116199] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[   13.159355] fbtft_of_value: regwidth = 16
[   13.159375] fbtft_of_value: buswidth = 8
[   13.159390] fbtft_of_value: debug = 0
[   13.159403] fbtft_of_value: rotate = 270
[   13.159416] fbtft_of_value: fps = 30
[   13.159430] fbtft_of_value: txbuflen = 32768
dmesg|grep /dev/fb provides no result.
ls /dev/fb* shows two devices fb0 and fb1
Cynical
  • 145
I believe the issue is due to the fact that while your driver is loaded and usable, Xorg seems to still pick the HDMI output (which you probably haven't disabled). You should tell Xorg to use the right framebuffer device, which defaults to fb1 according to this wiki page. You should be able to see this device name in dmesg output if you search for "graphics" or "fb_ili9486":
dmesg | grep graphics
graphics fb1: fb_ili9486 frame buffer, 320x480, ...
To tell Xorg which framebuffer to use, you have two options:
If you start Xorg from command line, use FRAMEBUFFER variable:
FRAMEBUFFER=/dev/fb1 startx # or startlxde, etc.
If you want Xorg to start automatically, modify its configuration files (/etc/X11/xorg.conf or files inside /etc/X11/xorg.conf.d):
Section "Device"
  Identifier "TFT"
  Option "fbdev" "/dev/fb1"
EndSection
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
