23
Aside from physical damage (treading on it), is there anything that I could do to the Pi that could irreversibly damage it?
More specifically, will anything I can do with code, or by prematurely taking out the SD card (I know this can corrupt the SD card), damage the Pi?
Darth Vader
  • 4,218
  • 47
  • 70
Tom Medley
  • 4,089
  • 33
  • 46
Here is a quote from Gert.
Do NOT experiment with trying to guess registers in that area. Especially if you start 'playing' with, or accidentally hit a power register you have the small, but distinct possibility of blowing up your PI.
http://www.raspberrypi.org/phpBB3/viewtopic.php?t=8496&p=101319
So, apparently, yes, there is the possibility of activating a power register and frying the RPI.
user606723
  • 464
You could overclock the RPi through over_voltage. Overclocking it through arm_freq and gpu_freq is supported, but over_voltage can damage the CPU and will void your warranty. You do this through your config.txt. Here is a related question that gives a bit more information on overclocking and its dangers.
Andrew Larsson
  • 1,614
  • 22
