26
I am trying to run a package on my Raspberry Pi:
At the terminal, I typed in “sudo apt-get install picap” followed by enter.
I get it installed but cannot execute "picap-setup" – instead an error message follows:
pi@raspberrypi:~ $ picap-setup Traceback (most recent call last): File "", line 1, in ImportError: No module named RPi
Python-dev and Rpi.GPIO are installed on the Pi. I also updated the Pi with the latest version with sudo apt-get update and sudo apt-get dist-upgrade.
Picap comes from : https://www.bareconductive.com/make/setting-up-pi-cap-raspberry-pi/
I am thankful for any hints.
99centsdreams
  • 369
5 Answers5
33
First of all, repeat following process
sudo apt-get install python-pip
pip freeze | grep RPi
see what you get after this second command, If you get a valid module for RPi.GPIO or not. And then following if not installed.
For Python 2
sudo apt-get install python-dev python-rpi.gpio
or
pip install RPi.GPIO
For python3
sudo apt-get install python3-dev python3-rpi.gpio
and then ( for python 2 or python 3):
picap-setup
These all worked for me, Just you need to verify pip freeze | grep RPi. And one more thing sometimes some modules are not available for normal user only for root user. Make sure. I did all above using my pi user.
titusfx
  • 103
BetaDev
  • 441
If Python RPi module is missing, one can install pip with all dependencies and then install the module using pip or go with the better approach and install the module alone:
sudo apt-get install python-rpi.gpio
for Python3 this one:
sudo apt-get install python3-rpi.gpio
dmnc
  • 161
For Windows
pip install python3-rpi.gpio
or
Greenonline
  • 2,969
  • 38
Dhiren Biren
  • 151
I had a similar issue with my Pi. Doing a simple pip install solved the issue.
if using pycharm on windows then it will work like this
  1. upgrade pip
    C:\Users\sandeep\PycharmProjects\newnum1\venv\Scripts\python.exe -m pip install --upgrade pip
  2. installing the module
  3. it worked for me should work for everyone
Jangir
