This post has a nice solution for using GPIO (and I2C) without root-privileges. This is useful if you're running an (web) app in a virtual environment as some ve-user, so as to shield off your whole Pi from that ve-user. But let's not digress.
The solution is basically that your ve-user must be member of gpio, and that root:gpio (not root:root) owns /dev/gpio.
pi@RPi2a ~ $ ls -l /dev/gpiomem
crw------- 1 root root 245, 0 Jan 1 1970 /dev/gpiomem # BEFORE
pi@RPi2a ~ $ sudo chown root.gpio /dev/gpiomem && sudo chmod g+rw /dev/gpiomem
crw-rw---- 1 root gpio 245, 0 Jan 1 1970 /dev/gpiomem # AFTER
The thing is: after a reboot, it's all back to the BEFORE situation. So how do you make it stick? Googling some, I found it's ruled by /etc/udev/rules.d/99-com.rules.
I guess (correctly?) root executes this at boot time. In it, there is:
PROGRAM="/bin/sh -c 'chown -R root:gpio /sys/class/gpio && chmod -R 770 /sys/class/gpio; chown -R root:gpio /sys/devices/virtual/gpio && chmod -R 770 /sys/devices/virtual/gpio'"
SUBSYSTEM=="input", GROUP="input", MODE="0660"
SUBSYSTEM=="i2c-dev", GROUP="i2c", MODE="0660"
SUBSYSTEM=="spidev", GROUP="spi", MODE="0660"
So I inserted this into the first line, just before the closing '":
; chown root.gpio /dev/gpiomem && chmod g+rw /dev/gpiomem
But that didn't work, nor did this variation: chown root:gpio /dev/gpiomem && chmod 660 /dev/gpiomem). So I've added that line to root's crontab (sudo crontab -e) like this:
@reboot chown root.gpio /dev/gpiomem && chmod g+rw /dev/gpiomem
This works, but it looks to me like fighting the symptom rather than the cause. So I tried to find what resets the ownership on /dev/gpiomem:
sudo grep -rnw /etc/ -e "/dev/gpio"
to no avail. Grepping the entire disk (/ instead of /etc/udev) breaks with grep: memory exhausted. It's a 256 MB Pi. I'm using, and want to stick to, Adafruit's Wheezy.
So the question is: what, where, how & why manipulates /dev/gpiomem?
