I have problem to connect on internet over Wi-Fi. Cable is not connected.
$ route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.0.1     0.0.0.0         UG    0      0        0 eth0
0.0.0.0         192.168.0.1     0.0.0.0         UG    303    0        0 wlan0
192.168.0.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
192.168.0.0     0.0.0.0         255.255.255.0   U     303    0        0 wlan0
After command $ ifdown eth0 internet working.
File /etc/network/interfaces:
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet static
    address 192.168.0.80/24
    network 192.168.0.0
    gateway 192.168.0.1
    broadcast 192.168.0.255
    dns-nameservers 192.168.0.1 8.8.8.8
    dns-options rotate
auto wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
How to change configuration, to work over cable if cable is connected and work over Wi-Fi if cable is not connected ?
"How to change configuration" SIMPLE revert to the default settings which work out of the box. See How do I set up networking/WiFi/Static IP.
If you REALLY must use static do it properly!
