I would like to ask if it possible to get NMEA code/string from a GPS module that connected to one of the GPIO of a Raspberry?
techraf
  • 4,353
  • 43
CeciliA
You don't mention which GPS module you have, so I can not provide a definitive yes, but given the right GPS module it is possible using the UART (tx/rx pins). Another alternative depending on your module is to use one of the USB ports (either directly connected for modules that have a usb cable or via a USB to TTL cable). Adafruit has a complete tutorial covering the use of a GPS module with the Raspberry Pi.
Steve Robillard
  • 34,988
  • 106
  • 110
Getting GPS's Data: GPS receives data from output NMEA0183, tcp: // 2947, class: TPV & amp; tag: GPGGA.
Next is the step in the terminal to access GPS data:
  1. Install: gpsd, gpsd-clients. (Note: install both use apt-get install)
  2. Reboot (sudo reboot or sudo init 6)
  3. Sudo dpkg-reconfigure gpsd (Note: configuration baudrate = 9600, 8 N 1 data format).
  4. Serial tests with the command: gpspipe -r or cat /dev/ttyS* or /dev/ttyUSB* (Note: the * sign matches the read, use command ls /dev/ttyS*, /ttyS*, /ttyAMA* or /ttyUSB* or others).
  5. If point 3 fails, stop and disable socket 2947 for a while. Try to type with the command & then reboot Raspberry Pi immadiately:
    $ sudo systemctl stop gpsd.socket
    $ sudo systemctl disables gpsd.socket
  6. Then start and enable gpsd socket with command:
    $ sudo systemctl start gpsd.socket
    $ sudo systemctl enables gpsd.socket
  7. Start daemon using command:
    $ sudo gpsd /dev/ttyS0 –F /var/run/gpsd.sock
  8. For live straming:
    $ cgps –s or $ cgps or gpsmon
In practice way to get stream data GPS from NMEA Output, you can also use a simple command:
$ timeout 10s gpspipe -w -n 10 | grep -m 1 speed
$ timeout 10s gpspipe -w -n 10 | grep -m 1 speed | jq
Using json query / jq for pretty printing.
In python script:
def getGPS():
    gpspipe= "timeout 10s gpspipe -w -n 10 |  grep -m 1 speed"
    p = subprocess.Popen(gpspipe, stdout = subprocess.PIPE, shell = True)
