I’m newbie and I’ve put my best effort to solve this and the following are the steps I've followed,
  1. Installed, RASPBIAN JESSIE WITH PIXE
  2. /etc/network/interfaces, /etc/wpa_supplicant/wpa_supplicant.conf & /etc/dhcpcd.conf are as mentioned & attached.
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa_supplicant.conf,
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
update_config=1
network={
        ssid="YOUR WIFI NETWORK NAME"
        psk="YOUR WIFI PASSWORD"
        proto=WPA
        key_mgmt=WPA-PSK
        pairwise=TKIP
        group=TKIP
        id_str="YOUR WIFI NETWORK NAME"
dhcpcd.conf,
interface wlan0
static ip_address=192.168.0.103/24
static routers=192.168.0.1
static domain_name_servers=192.168.0.1
After doing this, I’ve connected raspberry pi to wifi and can remotely access it using VNC player. But in VNC player, I could not connect to any website but I can access my router using 192.168.0.1 (my router). Also, when I take my cursor to wifi symbol over top right corner it shows me that it is associated to my router and configured with ip I’ve mentioned.
I think I’m missing something but I don’t know what it is.
P.S: if I connect using LAN and share my wifi then it works. Also, if I type “ifconfig wlan0” then “inet addr” field has an address beside it and "ifconfig" shows me connected router.
imbond
You are using obsolete settings in /etc/network/interfaces. If you are going to put dhcp in /etc/network/interfaces there is no point modifying dhcpcd.conf because dhcp disables dhcpcd.
To fix see How do I set up networking/WiFi/Static IP
NOTE this has nothing to do with your problem (whatever this is - your question is unclear; "connected RSP to wifi" what is a "RSP"?).
If you get rid of the static IP address and connect the Pi to your router (via Ethernet or WiFi) and let the router do its job everything should work.
