32
I have a custom python app that I wanted to have started automatically on the RPi with the official touch screen.
This used to work fine without a sleuth of boot messages appearing until the latest update in Jessie with the PIXEL desktop. My 'asplashscreen' script that I used to use now is littered with boot messages again.
I dumped 'asplashscreen' and since Plymouth has finally been patched to work (after PIXEL release) I now have Plymouth showing a pretty boot screen, but the old methods of silencing the boot messages don't seem to work anymore.
How can I remove ALL boot messages (including auto-login and kernel) messages?
G Trawo
  • 840
Please note that removing the output of message can also hinder your ability to troubleshoot your system after. You may want to wait until you are in the finishing stages before applying these fixes.
As of December 2016, a lot of the old methods seemed to have stopped working. I created this question/answer post because it took me many hours to aggregate all the solutions. What I did to remove ALL the boot up text (even login messages):
1.) Change /boot/cmdline.txt
sudo nano /boot/cmdline.txt
Change the console from tty1 to
console=tty3
Add this to the end of the line. 'loglevel=0' removes most of the messages from the boot. You can also use 'loglevel=3', but some boot messages may re-appear.
quiet splash loglevel=0 logo.nologo vt.global_cursor_default=0
If you are going to use Plymouth add this:
plymouth.ignore-serial-consoles
2.) Tell dmesg to be quiet
sudo nano /etc/rc.local
Add this before 'exit 0':
#Suppress Kernel Messages
dmesg --console-off
This should take care of most boot messages this far. #2 also took care of the 'watchdog watchdog0: watchdog did not stop!' message on shutdown for me.
3.) Change the auto login in systemd (Hides the login message when auto-login happens)
sudo nano /etc/systemd/system/autologin\@.service
Change your auto login ExecStart from:
ExecStart=-/sbin/agetty --autologin pi --noclear %I $TERM
To:
ExecStart=-/sbin/agetty --skip-login --noclear --noissue --login-options "-f pi" %I $TERM
Make sure to change 'pi' to the username you use!
4.) Change /etc/pam.d/login (removes the Kernel version from showing when you auto-login)
sudo nano /etc/pam.d/login
Change the line
session    optional   pam_exec.so type=open_session stdout /bin/uname -snrvm
To be
5.) Add .hushlogin
touch ~/.hushlogin
or Remove Message of the Day -MOTD (alternative to 5)
sudo update-rc.d motd remove
Now my boot just shows the Plymouth boot screen, and goes into my python GUI.
G Trawo
  • 840
1. Remove the rainbow splash screen enter image description here
sudo nano /boot/config.txt
add below line to the end of file
disable_splash=1
check if this config take effect (optional)
sudo reboot
2. Hide the Raspberry logo enter image description here
Add below line to end of file
logo.nologo
sudo reboot
3. Hide the messages
quiet
change console
console=tty1 --> console=tty3
sudo reboot
4. Change splash screen
copy your custom splash to home directory and replace raspberry's splash.png
sudo cp ~/splash.png /usr/share/plymouth/themes/pix/splash.png
sudo reboot
5. Hide the cursor
Add below line to the file /boot/cmdline.txt
sudo reboot
6. Result Check the video on this link
not2qubit
  • 1,439
ThanhLe
  • 311
I would have commented on someone else's answer but I don't have enough reputation yet. To all this, I'd add that (as of Debian/Raspbian Buster at least), it seems like dmesg errors will break through Plymouth and replace your custom splash screen as a console message. For example, the typical undervoltage notification will do so. It's possible that undervoltage was promoted from STDOUT to STDERR in this major release.
It may be necessary to add the following line to the end of /etc/rc.local before the final exit: dmesg --console-off.
