I have a Snapper Robotic Arm kit from Trossen Robotics. The servos are powered externally via 7v/5a supply that came with the kit. I power the Geekduino via USB to micro-USB connection, and upload the sketch from my Macbook Pro.
Whenever I run a sketch like this or an animation written using this library, the servos run & animate just fine. If, however, I power the Geekduino by connecting the USB cable to my Raspberry Pi 3 instead, the servos run erratically: halfway through an animation, a servo that has any load on it at all will give way, or a servo will start "ticking"/moving a few degrees at regular one second intervals, or both.
I just can't figure why the RPi scenario doesn't work. Is it something to do with the USB port in the RPi? What else can I investigate that I'm not thinking of? The Raspberry Pi 3 is powered by a recommended 5v/2.5a supply, and I've properly disabled anything that would interfere with the serial port (that I know of).
NOTE: lsusb on the RPi lists the GeekDuino as an FTDI device, rather than Arduino or Atmel, if that makes a difference.
Gregir
  • 121
Your GeekDuino is based on ATMega328 which AFAIK doesn't provide any UART flow control. So, if you send too many bytes at once, you will lose some of the bytes and thus risk to get erratic behavior depending on the protocol you have. I know you run the same software on both Mac and RPi, but they certainly have different UART drivers, which may affect how many bytes they send at once.
If possible, make your GeekDuino send back whatever it receives from the UART, then you'll have a clear picture of what you receive.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
This turned out to be an issue of powering the Geekduino from any of the Raspberry Pi's ports. I swapped out the Geekduino for an Arduino Uno, used the USB A to USB B cable, put the Robot Geek sensor shield on it, and ran my programs. They servos animate fine when the Arduino is powered by the Raspberry Pi now, as well as the Macbook Pro.
Gregir
  • 121
