I am trying to install GStreamer.
I have added the following line /etc/apt/sources.list:
deb http://vontaene.de/raspbian-updates/ .main
Calling the apt-get update command generates the following error:
E: Malformed line 2 in source list /etc/apt/sources.list (dist parse)
E: The list of sources could not be read."
I tried several ways but nothing seems to work.
techraf
  • 4,353
  • 43
bma
tl;dr Start with fresh Raspbian and do not alter /etc/apt/sources.list to install GStreamer. Trying to fix APT repository is possible, but usually time-consuming task.
You can install GStreamer from the official repositories (as suggested in this answer):
sudo apt-get install gstreamer1.0-tools
Regarding your question: you need to add space between . and main.
man sources.list shows the following structure for the /etc/apt/sources.list file:
deb [ options ] uri suite [component1] [component2] [...]
APT tries constructs an exact URL to the packages using:
http://<uri>/dists/<suite>/<component1>/<component2>
In case of GStreamer which is served from http://vontaene.de/raspbian-updates/dists/main/, the correct setting for sources.list is:
deb http://vontaene.de/raspbian-updates/ . main
It translates to http://vontaene.de/raspbian-updates/dists/./main/ - a reachable addres.
After setting the repository, you'd need to configure the keys. Anyway, currently setting this is unnecessary, see the top of the answer.
techraf
  • 4,353
  • 43
