I have a Raspberry Pi that will be used for logging sensor data while not connected to the internet. Since the Raspberry Pi doesn't have an RTC, and to still get the actual time, I want to use a GPS receiver for the time. I would like to use gpsd and chrony to achieve this. I chose chrony, as it offers some advantages over ntpd that I'll be using later on.
I have installed gpsd and chrony from the Raspbian repository. My /etc/default/gpsd:
START_DAEMON="true"
USBAUTO="true"
DEVICES="/dev/ttyACM0"
GPSD_OPTIONS="-n"
gpsd works, I can verify that with cgps (which says Status: 3D FIX).
My /etc/chrony/chrony.conf:
refclock SHM 0 offset 0.05 delay 0.5 refid SHM0 noselect
makestep 1 10
maxupdateskew 5
local stratum 1
manual
allow
pidfile /tmp/chronyd.pid
driftfile /var/lib/chrony/chrony.drift
keyfile /etc/chrony/chrony.keys
commandkey 1
logdir /var/log/chrony
log tracking
noclientlog
logchange 0.1
dumponexit
dumpdir /var/lib/chrony
cmdallow 127.0.0.1
lock_all
bindcmdaddress 127.0.0.1
bindcmdaddress ::1
Now I expect chrony to keep the date and time of my Raspberry Pi in sync. However, the result:
On my own pc:
$ date
Mon 12 Dec 08:58:13 CET 2016
On my Raspberry Pi:
$ date
Mon 12 Dec 16:11:39 GMT 2016
If I check on chrony, it does seem to get date from the gpsd daemon, as shown by this table that lists an ~8 hour time difference, which seems about right:
$ chronyc sources
210 Number of sources = 1
MS Name/IP address         Stratum Poll Reach LastRx Last sample
#? SHM0                          0   4   377    22  +29618s[+29618s] +/-  250ms
I can set the time with chronyc:
$ sudo chronyc
chrony version 1.30
Copyright (C) 1997-2003, 2007, 2009-2014 Richard P. Curnow and others
chrony comes with ABSOLUTELY NO WARRANTY.  This is free software, and
you are welcome to redistribute it under certain conditions.  See the
GNU General Public License version 2 for details.
chronyc> password ****
200 OK
chronyc> settime Dec 12, 2016 12:11:39
200 OK
Clock was 15194.06 seconds fast.  Frequency change = 0.00ppm, new frequency = 12.75ppm
$ date
Mon 12 Dec 12:11:44 GMT 2016
So why isn't chronyd setting my system time by itself?
Frank Kusters
  • 221
My chrony.conf now looks like this, and chrony does synchronize with GPS:
driftfile /var/lib/chrony/drift
makestep 1 10
commandkey 1
allow
# set larger delay to allow the NMEA source to overlap with
# the other sources and avoid the falseticker status
refclock SHM 0 refid GPS precision 1e-1 offset 0.9999 delay 0.2
I haven't taken the time to figure out why this configuration does work. There's one more problem left: if the GPS receiver is not plugged in at system startup, then chrony will not synchronize the time when the receiver is plugged in.
Frank Kusters
  • 221
Remove noselect from the refclock line, otherwise that refclock will not be taken into account.
techraf
  • 4,353
  • 43
You have to use chronyc makestep in your terminal to sync your system time immediately. See the documentation for chrony:
Normally chronyd will cause the system to gradually correct any time offset, by slowing down or speeding up the clock as required. In certain situations, the system clock might be so far adrift that this slewing process would take a very long time to correct the system clock.
The makestep command can be used in this situation. There are two forms of the command. The first form has no parameters. It tells chronyd to cancel any remaining correction that was being slewed and jump the system clock by the equivalent amount, making it correct immediately.
