I just bought a raspberry pi 3 with not previous experience. I want to run my pi without keyboard and mouse.
I do have an old tv that can be used to display the output. Now this way I first got a message 'internet connection required' when I booted up.
Connected the pi with ethernet to my laptop and enabled connection sharing (which had no effect on the pi's internet connection for some reason).
So I connected the pi directly to my router. Now by some trial and error I found out the ip of my pi, in this case 192.168.2.13 when running ping 192.168.2.13 I get responses when I plug the ethernet cable in, and none when I take it out. (name is 'recovery'?)
The problem is that I can't seem to ssh into the pi, running ssh 192.168.2.13 returns 'Connection refused'. PuTTy can't connect to it either.
I can't seem to find a solid guide which works for me. Just wondering if it is possible at all to ssh to my pi when it's still in the selection screen?
(I have a pi 3 currently in the NOOBS selection screen for an OS)
Referenced guides:
Ivafo
  • 131
There is a similar question: SSH not working with fresh install
Here is the accepted answer from the user techraf, which is a quote from the raspberry pi documentation:
As of the November 2016 release, Raspbian has the SSH server disabled by default. You will have to enable it manually.
Enter sudo raspi-config in the terminal, first select advanced options, then navigate to ssh, press Enter and select Enable or disable ssh server.
For headless setup, SSH can be enabled by placing a file named 'ssh', without any extension, onto the boot partition of the SD card.
uebme
