Whenever I try the command sudo apt-get update it outputs this error:
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?
I couldn't find any answers online. Can someone please help?
Rowan Lerowsky
  • 114
Because somewhere on the way you must have configured an APT repository pointing to an HTTPS URL (check the files at /etc/apt/sources.list.d/).
Per the error message to fix the problem you need to run:
sudo apt-get install apt-transport-https
and most likely also:
sudo apt-get install ca-certificates
techraf
  • 4,353
  • 43
I have checked /etc/apt/sources.list.d/. In my case there I found two files. raspi.list and influxdb.list. I found https in influxdb.list file. I removed influxdb.list file with rm command. Now my Raspberrypi works perfectly. I am able to run sudo apt-get update without any errors.
