I followed this https://raspberrypi.stackexchange.com/a/56513/57412 trying to use my RC522 on spi 1.0 but I'm stuck.
Could someone give me a hand wiring correctly (I hope it is) and how to use the right Python library and codes in order to get it working.
I use RPi3.
I added this to /boot/config.txt:
dtoverlay=spi1-3cs
dtoverlay=pi3-disable-bt
and if I search, I can see this:
ls /dev/spi*
/dev/spidev0.0  /dev/spidev0.1  /dev/spidev1.0  /dev/spidev1.1   /dev/spidev1.2
I used these repos:
https://github.com/mxgxw/MFRC522-python
https://github.com/lthiery/SPI-Py
and here is the wiring list:
Name    Pin #   Pin name
SDA     36      BCM16
SCK     40      BCM21
MOSI    38      BCM20
MISO    35      BCM19
IRQ     None    None
GND     Any     Any Ground
RST     None    None
3.3V    1       3V3
How can I find where the RC522 is actually connected? On which spidev?
g0rg
Use this repository: https://github.com/ondryaso/pi-rc522
It implements IRQ (Interruption Request) that makes insignificant CPU usage and much more efficient the reading process (non-blocking). You will need to add one more cable from the IRQ pin on the MFRC522.
Daniel
http://abyz.me.uk/rpi/pigpio/index.html#Type_3 shows the needed SPI GPIO.
For the auxiliary SPI (spidev1.x) you need to connect miso, mosi, sclk.
You also need to choose a slave select line as follows. It doesn't matter which you use.
ce0  for spidev1.0
ce1  for spidev1.1
ce2  for spidev1.2
joan
  • 71,852
  • 76
  • 108
I actualy get it working with my previous settings here in my first post. However I think it's because i used an older version according to my "uname -a":
Linux raspberry 4.4.13-v7+ #894 SMP Mon Jun 13 13:13:27 BST 2016 armv7l GNU/Linux
So i think that the problem could come with my tests under the last Pixel desktop release.
I could mark this post as closed if anyone could confirm my opinion on pixel or not ...
g0rg
