I started working with a Raspberry Pi Compute Module and 2 PiCamera after long time. I lost all the notes about our old class project, I quite don't remember all our procedures
Each camera is connected and works well (Tried raspistill/raspivid command).
I found this instruction stored into a .sh file that "should" start the stream of the 2 cameras.
sudo uv4l --sched-rr --driver raspicam --video_nr=0 --stereoscopic-mode=side_by_side --encoding=mjpeg --width=1280 --height=480 --server-option='--port=9000'
I am able to access in ssh mode to my Raspberry and launch this sh file. I would to receive the video stream in my computer. I tried to record stream with VLC but adresses like http://:9000 does not work.
Can anyone help me whit these problems
1) the .sh script generates these lines
<notice> [core] Trying driver 'raspicam' from built-in drivers...
<warning> [core] Driver 'raspicam' not found
<notice> [core] Trying driver 'raspicam' from external plug-in's...
<notice> [driver] Dual Raspicam Video4Linux2 Driver v1.9.36 built Apr  8 2016
<notice> [driver] Selected format: 1280x480, encoding: mjpeg, JPEG Video Capture
<notice> [driver] Framerate max. 30 fps
<notice> [driver] ROI: 0, 0, 1, 1
<notice> [core] Device detected!
<notice> [core] Registering device node /dev/video0
but how to know if the stream is properly generated? How to access to dev/video0?
2) how to get the stream with VLC? All my tries went wrong
3) Is there any other better way to stream the stereo cameras?
Tank you all in advance.
marcoresk
  • 161
After following the link provided by strumpet, the correct address to stream the video with VLC is
http://raspberrypi:port/stream/video.mjpeg
where raspberry is the IP and port is the selected port in the uv4l command (9000 in my case).
marcoresk
  • 161
