I'm trying to share some files with my macbook (running OS X El Capitan v10.11.4) so that I can edit them without uploading them after each edit.
I've tried this guide and I can connect to the pi and see the shares. When I try and access them though, I get this:
The operation can't be completed because the original item for "home" can't be found.
Why would I get that message?
[Edit] @ Milliways - this is step by step what I did:
  1. Downloaded NOOBS to install Raspbian from the raspberry pi website.
  2. Set a static IP address on the PI.
  3. Enabled SSH access.
  4. Ran the sequence of commands* below.
  5. Connected from my Macbook to the Raspberry PI in OSX Finder and selected whereupon I could see the default share that netatalk suggests.
  6. Clicked on the home share and when prompted, entered the pi | raspberry default pi credentials.
*Sequence of commands:
sudo apt-get update
sudo apt-get install netatalk
sudo /etc/init.d/netatalk stop
sudo nano /etc/netatalk/AppleVolumes.default
sudo /etc/init.d/netatalk start
...and that's when I got the error message mentioned above.
[Edit2] - This is what my netatalk file changes look like:
# The line below sets some DEFAULT, starting with Netatalk 2.1.
:DEFAULT: allow:pi options:upriv,usedots,noadouble,rw
# By default all users have access to their home directories.
~/                      "home"
/                       "pi-root"
Jon Cage
  • 133
As Apple abandoned AFP in favor of SMB3 you should try using samba instead.
user49015
  • 2,712
You have followed an old SysV guide, and probably messed something up. See https://raspberrypi.stackexchange.com/a/39665/8697 - all you should NEED to do is install netatalk. You could then customise /etc/netatalk/AppleVolumes.default, but this is NOT necessary to get home.
I use netatalk all the time, and often cannot connect, after my Mac has been sleeping, so I restart the service on the Pi with sudo systemctl restart netatalk.
try NFS protocol, which is native for Unix* OS-es and is fast
  1. Share a directory in RPi (/etc/exports)
  2. Mount it from Mac (sudo mount -o rsize=32768,wsize=32768,intr,noatime -t nfs RPi_IP_addr:/sharename /folder_to_mount_it )
or Using SSHFS which is slower, but secure (encrypted)
  1. Enable ssh on RPi
  2. Install sshfs client on Mac (http://osxfuse.github.io/)
  3. Mount SSH resource on Mac (sshfs user@RPi_IP_addr:/dir /mount_folder -ocache=no -onolocalcaches -ovolname=ssh)
Samba also should work
jet
  • 379
