Raspberry Pi 3 Model B running Raspbian "Jessie with PIXEL" (Release 2016-09-23).
It appears that all the WiFi networks that requires authentication other than a PSK are grayed out in the menu.
What is the reason behind this? Not supported by driver or not support by GUI?
Thanks!
Screen
Radium Zheng
  • 309
Turns out it is just the GUI that does not support WPA2 Enterprise. Was able to connect to those grayed-out networks by manually modifying /etc/wpa_supplicant/wpa_supplicant.conf as follows:
network={
    ssid="VostroNet"
    key_mgmt=WPA-EAP
    eap=TTLS   //put your EAP method
    identity="xxxxx"
    password="xxxxx"
    phase2="auth=MSCHAPv2"
Aren Cambre
  • 103
Radium Zheng
  • 309
Most of the answers I found online were obsolete, with the latest release of Raspbian. I made a post with the fix, Connecting a Raspberry Pi 3 to Enterprise Wifi:
Type this in your terminal :
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Edit the contents of the file to the following :
network={
      ssid=""
      priority=1
      proto=RSN
      key_mgmt=WPA-EAP
      pairwise=CCMP
      auth_alg=OPEN
      eap=PEAP
      identity=""
      password=""
      phase1="peaplabel=0"
      phase2="auth=MSCHAPV2"
Press Ctrl+O to save and Ctrl+X to exit.
Fill in the blanks:
  • ssid with your University wifi’s ssid(name);
  • identity with your username, and;
  • password with your password.
Greenonline
  • 2,969
  • 38
For the eduroam environment in our university, the wpa_supplicant.conf looks like this:
update_config=1
country=NL
network={ ssid="eduroam" scan_ssid=1 key_mgmt=WPA-EAP eap=PEAP identity="name@university.nl" password="MyPassword" phase1="peaplabel=0" phase2="auth=MSCHAPV2" }
