What is the password to switch user to root. I just put the new ad card into rpi3b and in trying to su root I am asked for a password and I enter raspberry and get authentication error.
root user on Raspbian doesn't have a valid password at all. This is an intentional security measure which prevents someone from logging in as root to your board. Raspbian comes with a default pi user who has a password raspberry; once you change that password your RPi gets some basic security. Having a default root password would require you to change passwords for both users in order to secure your RPi.
You can set root password by running sudo passwd. This is only recommended if you want to play with login scripts of your pi user or sudo settings - having a root password will enable you to login and rescue your system if you accidentally lock yourself out of your pi account or break sudo (the latter specifically can only be fixed if you login as root). Otherwise I wouldn't do it.
- 28,277
- 6
- 54
- 147
If I remember correctly there is no root password by default.
If you want to login as root try
sudo su # login as root
passwd # set-up a root password
- 71,852
- 5
- 76
- 108
I tried different passwords then finally password is: raspberry
- 34,988
- 18
- 106
- 110
- 1
