I have a gps tracking script using node-gpsd module. When the automobile pass over a checkpoint the script plays a sound like "you are in XXXXX stop" and then waits 30 second to start tracking for the automobile ubication. All this tracking system is running on a raspberry pi zero in a bus.
Here is my code:
var turf = require('turf');
var fs = require('fs');
var gpsd = require('node-gpsd');
var listener = new gpsd.Listener();
var exec = require('child_process').exec;
var sleep = require('sleep');
function estaDentro(long,lat,coords){
    var posicion = turf.point([long, lat]);
    var pol = turf.polygon([coords]);
    return turf.inside(posicion, pol);
function operacion(tpv) {
        var lat = tpv.lat;
        var lng = tpv.lon;
        var zonasJson = fs.readFileSync("audio/jsons/zonas.json");
        var zonas = JSON.parse(zonasJson);
        for (i=0; i<zonas.zonas.length; i++){
            if(estaDentro(lng,lat,zonas.zonas[i].coords)===true){
                var zona = i;
                var paradaJson = fs.readFileSync("audio/jsons/"+zona+"paradas.json");
                var parada = JSON.parse(paradaJson);
                for(x=0; x<parada.paradas.length; x++){
                    if(estaDentro(lng,lat,parada.paradas[x].coords)===true){
                        exec('mpg123 audio/arribando.mp3 audio/paradas/'+parada.paradas[x].nombre+'.mp3')
                        listener.unwatch()
                        sleep.sleep(30)
                        setTimeout(function(){ listener.watch(); }, 30000);
function correr() {
    listener.on('TPV', function (tpv) {
        operacion(tpv);
    listener.connect(function() {
        listener.watch();
correr();
I need to run this script at boot, but I cant, really, I tried in /etc/rc.local writing this on that file:
/usr/local/bin/node /home/pi/trak3.js &
Then I reboot and nothing happens, in the log it appears that the command its run but for some reason it closes.
Another approach was inserting in crontab like this
@reboot /usr/local/bin/node /home/pi/trak3.js &
This works, but the script runs with an error, it play the sound repeatedly 3 times in a row, but if I run the script myself writing in the command line it play the sound once.
I dont know why I cant run node via the /etc/rc.local and why that happen when it run via crontab. This is making me crazy haha.
Thank you
=============Update 05 November 2016 ==============
I got the conclusion that the problem is caused by the paths of the modules, because I made a test script without dependencies and it executed fine at boot, I can get the path from modules downloaded from npm, but I cant get the paths from the integrated modules.
    var turf = require('/home/pi/node_modules/turf');
    var gpsd = require('/home/pi/node_modules/node-gpsd');
    var sleep = require('/home/pi/node_modules/sleep');
As you can see I need the "fs" and "child_process" path modules, do anybody knows how to solve this problem? thank you.
try using pm2. it's designed to run node.js scripts at boot, among other things. you can restart a script, you can look at its regular and error outputs in log files.
to start a node.js script at boot:
$ pm2 start app.js
for help:
$ pm2 -h
for a list of running processes:
pm2 list
to get details about one of the processes:
pm2 show
mahesh
  • 111
Most of us write and test our code as user "pi". At startup the Pi is running as "root" with a completely different environment and directory. I found it helpful to use "sudo -u pi ..." in my startup scripts to switch to the pi user as needed. Here's an example: https://github.com/oyamist/oyapi/blob/master/scripts/oyapi
Note also the explicit cd into the desired directory. Yours will be different.
OyaMist
  • 1,119
I had the same infuriating problem then I remembered I previously had to export NODE_PATH in my .bashrc file to start node. Your rc.local file should contain the path to your node_modules directory. Eg:
export NODE_PATH=/usr/local/lib/node_modules
Caleb Carroll
  • 91
