I was trying to transfer a 50 MB file to my Raspberry Pi 3 via samba and I noticed that after few seconds the transfer slows down until it stops, same thing via scp. It starts but after few seconds (5-7) the speed drops. I'm running the latest Raspbian jessie.
This is the dmesg output:
[ 4.272062] usbcore: registered new interface driver brcmfmac
[ 4.408506] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[ 4.418558] cfg80211: World regulatory domain updated:
[ 4.418584] cfg80211: DFS Master region: unset
[ 4.418593] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 4.418608] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.418621] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.418633] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.418647] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 4.418661] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 4.418674] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 4.418686] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.418698] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 4.443235] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 5.438938] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 5.438949] brcmfmac: brcmf_add_if: ignore IF event
[ 5.443389] brcmfmac: power management disabled
[ 5.962063] cfg80211: Regulatory domain changed to country: IT
[ 5.962079] cfg80211: DFS Master region: ETSI
[ 5.962085] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 5.962093] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 5.962101] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 5.962109] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 5.962115] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
[ 5.962121] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
And from iwconfig wlan0:
wlan0 IEEE 802.11bgn ESSID:"Name"
Mode:Managed Frequency:2.437 GHz Access Point: XX:XX:XX:XX:XX:XX
Bit Rate=72.2 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=70/70 Signal level=-36 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:540 Invalid misc:0 Missed beacon:0
Could be a driver issue? Router channel? What does Tx excessive retries:540 mean, too?
Update: ifconfig wlan0 reveals that i'm having several RX packets dropped (about 10%, even though disabling power management improved a bit).
In fact, sending data FROM the pi looks reasonably fast, sending TO the Pi is very slow (1-1.5 MB/s).
