Raspberry Pi 2, Model B Latest Raspbian Jessie - Headless
I have spent literally weeks of my spare time trying to debug this - so naturally, it's probably a simple problem I have mucked up.
I have tried multiple fresh installs, I now have access to my Pi through ssh over the wireless dongle I plug in.
The Pi's ethernet seemed to work on another persons install of Kodi, however it hasn't worked for me with Raspbian Jessie Lite, Raspbian Jessie, Raspbian Wheezy.
When I turn on the Pi the lights come on on the ethernet, both lights, the green light flashes intermittently at random intervals. SOMETIMES, when plugging in an ethernet cable, the light will flash for a while - but if anything it will just go to this random IP it has tried to set itself.
Files for perusal:
File: /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet static
allow-hotplug wlan1
iface wlan1 inet manual
/etc/wpa_supplicant
country=GB
update_config=1
network={
ssid="Healing Center"
psk="*******"
id_str="guy"
network={
ssid="ChediView3"
psk="********"
id_str="Chedi3"
ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:ff:9c:48
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:71 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:12431 (12.1 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:876 errors:0 dropped:0 overruns:0 frame:0
TX packets:876 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:70524 (68.8 KiB) TX bytes:70524 (68.8 KiB)
wlan0 Link encap:Ethernet HWaddr 40:a5:ef:07:f2:d4
inet addr:192.168.1.6 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::bdc8:3907:baea:c245/64 Scope:Link
RX packets:9284 errors:0 dropped:3694 overruns:0 frame:0
TX packets:3911 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2006150 (1.9 MiB) TX bytes:1610126 (1.5 MiB)
(at the moment there is no IP showing)
dmesg|grep eth0
[ 3.930077] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ff:9c:48
[ 9.867363] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 9.867552] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.390454] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.391527] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 28.760723] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 28.838301] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 28.990076] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 29.077783] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 30.600737] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 35.898452] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 35.969400] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 37.493017] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
So I know there are lots of questions related to this on the internet, but trust me, I have tried and tried and tried! I feel like there is something out of the ordinary happening, my assumption would be that the ethernet jack is faulty, however it does seem to have worked on the other installation of Kodi.
Thanks in advance for any help.
