I tried to get the 4 inch display working with my raspberry pi 3 (Waveshare Raspberry Pi 4 Inch Touch Screen TFT LCD(A) 320*480 for Raspberry Pi RPi Model B/Raspberry Pi 2 Model B/Raspberry Pi 3 Model B).
I always had a white screen until I found "Bim"s solution in this question (How to install Waveshare SpotPear 4 inch LCD in RaspberryPI 2?). I followed his answer step for step and it changed the color of the display to black.
What I know now:
  • the driver is already part of the raspbian kernel so I don't have to install it
  • I have to copy the waveshare overlay for the 4 inch display from https://github.com/swkim01/waveshare-dtoverlays (I used the overlay for linux kernel > 4.4) to /boot/overlays/
  • modify the /boot/config.txt by adding dtoverlay=waveshare35a,speed=14000000
someone another idea what I have to do to get this display working?
Aurora0001
  • 6,357
  • 25
  • 39
Ben
  • 111
Ok after hours of searching I found this tutorial that works like a charm!
http://www.circuitbasics.com/setup-lcd-touchscreen-raspberry-pi/
But CAUTION! skip step 3! You don't have to install rpi-firmware from https://github.com/notro/rpi-firmware when you use a linux kernel > 4.4. If you do that you will cause a kernel panic. Then you have to reinstall raspbian again.
The only problem that appears is missing touch callibration, maybe this is caused by the tutorial maybe not. If I can find a solution for that I will post it here.
Ben
  • 111
