So I installed Snappy Ubuntu Core just like the offical guide. Found its IP. Everything works. I Followed step two of the guide which is updating package.
sudo apt-get update && sudo apt-get dist-upgrade
After the update it says to reboot. So I do that and then It won't connect to the ethernet.
So I connect a monitor and keyboard login in and type ifconfig on terminal it returns the lo adapter and so has no ip address.
/etc/network/interfaces is pretty much empty, which is where I usually put a static IP in raspbian.
How do I fix this and/or where do I look for debug information?
Edit.
So after reflashing I note the packages which are dist-upgrade will update:
accountsservice apparmor apport apt apt-transport-https apt-utils base-files bash bash-completion bind9-host bsdutils cloud-init command-not-found command-not-found-data console-setup console-setup-linux curl dh-python distro-info-data dmidecode dnsmasq-base dnsutils dosfstools dpkg fuse gcc-5-base gnupg gpgv grep grub-legacy-ec2 ifupdown init init-system-helpers initramfs-tools initramfs-tools-bin initramfs-tools-core isc-dhcp-client isc-dhcp-common keyboard-configuration klibc-utils language-selector-common less libaccountsservice0 libapparmor-perl libapparmor1 libapt-inst2.0 libapt-pkg5.0 libbind9-140 libblkid1 libcurl3-gnutls libdns-export162 libdns162 libdrm2 libexpat1 libfdisk1 libfuse2 libgcrypt20 libglib2.0-0 libglib2.0-data libgnutls-openssl27 libgnutls30 libidn11 libisc-export160 libisc160 libisccc140 libisccfg140 libklibc libldap-2.4-2 liblwres141 liblxc1 libmount1 libp11-kit0 libpam-systemd libplymouth4 libpython3.5-minimal libpython3.5-stdlib libsmartcols1 libssl1.0.0 libstdc++6 libsystemd0 libtasn1-6 libudev1 libuuid1 libxml2 linux-firmware linux-headers-raspi2 linux-image-raspi2 linux-raspi2 lsb-base lsb-release lshw lxc-common lxcfs lxd lxd-client mdadm mount mtr-tiny openssh-client openssh-server openssh-sftp-server openssl plymouth plymouth-theme-ubuntu-text pollinate python3-apport python3-commandnotfound python3-distupgrade python3-problem-report python3-software-properties python3-urllib3 python3.5 python3.5-minimal shared-mime-info snapd software-properties-common sudo systemd systemd-sysv tzdata ubuntu-core-launcher ubuntu-release-upgrader-core udev update-notifier-common util-linux uuid-runtime vim vim-common vim-runtime vim-tiny wget
Edit2:
I tried reflashing and did a normal apt-get upgrade instead of a dist upgrade. Same problem.
