I am trying to make my Pi accessible via SSH regardless of which wireless network it is connected to. For this end I have setup a static IP address to the wlan0 interface. Problem is that I cannot SSH to the Pi, ping it from other devices or ping anything in the network from the Pi. However, I can browse internet and ping addresses such as www.stackexchange.com from the Pi.
The problem goes away if I shutdown the eth0 interface with sudo ifconfig eth0 down. Then everything works perfectly. However, eth0 is back and running after a reboot. How can I direct all traffic to prefer the wlan0 interface instead of (not connected) ethernet?
I have the model 3b and am running Raspbian Jessie. My network/interfaces file
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
At the end of my dhcpcd.conf I have
interface wlan0
static ip_address=192.168.0.240/24
static routers=192.168.0.1
static domain_name_servers=192.168.0.1
and 192.168.0.240 is the address I try to ping/connect to.
When I ping other devices from the Pi while eth0 is active, I can see the Pi tries to ping from the address of the ethernet, although there is no ethernet cable attached and I want wifi to be used. This is how I figured to disable it and it seems to be the cause of the problem. Moreover, upon booting I get the message.
Waiting for network for 110 additional seconds
In a nutshell: Pi seems to use wrong network interface, how to fix?
Edit: ifconfig output
eth0      Link encap:Ethernet  HWaddr b8:27:eb:df:e2:1a
          inet addr:192.168.43.24  Bcast:192.168.43.255  Mask:255.255.255.0
          inet6 addr: fe80::8ed2:5c2a:b54f:d28c/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:420 errors:0 dropped:0 overruns:0 frame:0
          TX packets:121 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:37528 (36.6 KiB)  TX bytes:19320 (18.8 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:88 errors:0 dropped:0 overruns:0 frame:0
          TX packets:88 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:7689 (7.5 KiB)  TX bytes:7689 (7.5 KiB)
wlan0     Link encap:Ethernet  HWaddr b8:27:eb:8a:b7:4f
          inet addr:192.168.43.224  Bcast:192.168.43.255  Mask:255.255.255.0
          inet6 addr: fe80::fc57:9494:65ae:1475/64 Scope:Link
          RX packets:2547 errors:0 dropped:946 overruns:0 frame:0
          TX packets:146 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:316994 (309.5 KiB)  TX bytes:17769 (17.3 KiB)
milez
  • 115
Disable your eth0 interface on boot if you really don't need it.
Add sudo ifconfig eth0 down to /etc/rc.local, before any exit 0.
Addendum: The waiting for network problem could be solved by removing a permanent ip=x.x.x.x entry in /boot/cmdline.txt.
But disabling the eth0 interface still helped in preferring the wireless interface.
Your eth0 has 192.168.43.24 and wlan0 192.168.43.224. Neither of these agrees with 192.168.0.240/24 which you have attempted to set as static. (I will add my usual comment - there are better ways than using static.)
It is unclear what network you are trying to ping from, but presumably it is on a different subnet.
The fact that you have an inet address on eth0 implies the link is getting an address from somewhere, either it is connected or you have assigned it.
You have presumably misconfigured something, and supplied insufficient information for anyone to debug.
The kludge suggested, which you seem to have accepted, is just that - a kludge. Some of the other suggestions are just ways of avoiding the real problem, and will likely cause problems in future.
I suggest you actually solve your real problem, or just re-install the OS and start again.
If your problem is solved by sudo ifconfig eth0 down, simply remove lines
auto eth0
allow-hotplug eth0
from /etc/network/interfaces so it never goes up. This will also speed up your boot time since you won't be bringing the interface up and down unnecessarily.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
Maybe things would be easier if you keep the stock configuration on the pi and configure the DHCP daemon in your router to assign a fixed IP to the MAC address of the PI's wifi.
Additionally: Having SAMBA running on your PI will make it announce its name, so that it can be seen by windows machines on your net.
