I'm using wheezy on my raspi and wanted to install dialog.
sudo apt-get install dialog
E: Package 'dialog' has no installation candidate
So I look up the source
Package: dialog
Versions:
1.1-20120215-2 (/var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_main_binary-armhf_Packages)
 Description Language:
                 File: /var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_main_binary-armhf_Packages
my source.list looks like that
deb http://archive.raspbian.org/raspbian wheezy main contrib non-free
deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free
After apt-get update I have the same problem.
What source do I need to add?
Thanks
xhallix
  • 129
looks like the default live cd needs a repo update
sudo add-apt-repository universe
Marc Magon
  • 111
Confirm you are actually on Wheezy by running cat /etc/os-release which will probably print something like
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
there are threads over here https://askubuntu.com/a/14693/590737 and https://ubuntuforums.org/showthread.php?t=1704342 which are related to ubuntu but should pretty much apply here as well
Consider using Raspbian/Jessie if you can and see if it works
last resort, directly install the deb from here but this might break something so consider having a backup of the SD card in case it does
http://archive.raspbian.org/raspbian/pool/main/d/dialog/
Shreyas Murali
  • 2,446
