Here is what I am trying to achieve:
When I startup my Pi 3 I would like it to directly launch into Firefox in fullscreen-mode directly. Or more specifically - no edges like toolbars etc., just the webpage.
I´m going to use a screen to show my own calendar and health status. And the idea is not to have a mouse or keyboard connected.
Has anyone done this before?
I´m starting to work on my own solution, but if someone has already done this I would appreciate the help.
techraf
  • 4,353
  • 43
joedwardson
I've done this with chromium, should be similar for firefox.
sudo nano start.py
Contents of new file:
import os
os.system("chromium-browser --kiosk http://localhost/")
Then edit bashrc
sudo nano ~/.bashrc
Added to bottom of file:
DISPLAY=:0 python start.py &
Running
source ~/.bashrc
Should test whether the new file works. Try replacing chromium-browser with firefox. If that doesn't work you could always use chromium.
Tom Lee
  • 33
I have answered this before here
If you are using Jessie then there should already be an existing folder for LX-Session. The folder is the following:
/home/pi/.config/lxsession
if you are using an older version then you can create it using:
mkdir -p /home/pi/.config/lxsession
Now, you can create a file :
nano /home/pi/.config/lxsession/autostart
add the tag in the file of your browser:
 @firefox-esr (@iceweasel) # whichever you are using
press CTRL+O and CTRL+X
then reboot your Pi:
 sudo reboot
This should get your browser working on reboot of Pi.
Notes:
try installing the firefox-esr using:
sudo apt-get install firefox-esr
Try finding autostart file in the lxsession/ folder,
for some Pis it is in
  ~/.config/lxsession/LXDE-pi/
or
   ~/.config/lxsession/LXDE/
To have FireFox perform a clean start up. Need to go to about:config and search for exit then toggle " browser.helperApps.deleteTempFileOnExit " to false on reboot FireFox will open clean.
Shan-Desai
  • 1,541
  • 28
