I am connected via wlan to the internet. I was wondering where my password is saved on the raspberry pi. Once I saw it in plain text somewhere. I thought it was under
/etc/wpa_supplicant/wpa_supplicant.conf
But this file is empty. I tried
/etc/network/interfaces
as well. This file is not empty, but there is no information about my password. Then I tried
grep -r -i "MY_WLAN_NAME" ./
and
grep -r -i "wlan0" ./
without any proper results. Do you have any idea where my password could be located at, or at least how to find it?
Further information: I am using a raspberry pi 3 model b; operating system: raspbian.
Chris311
  • 43
If you are using Raspbian and the default setup, WiFi details will be in /etc/wpa_supplicant/wpa_supplicant.conf. NOTE You need to use sudo to access the contents (this is a security setting to protect passwords).
/etc/network/interfaces should also exist, and CAN be used to configure WiFi, but is not standard, and not recommended.
There are many different ways of setting networks, but these require specific changes on your part.
How do I set up networking/WiFi/Static IP describes the standard file settings.
If "connman" is your default network manager on you pi then you will have all the relevant setting regarding your wifi will be in one of the directories in "/var/lib/connman".
The name of the directory in actually the wifi-identifier (i don't know the official name for this id).
And you can figure out the id by running connmanctl services and checking the id against the AccessPoint name.
flide
