I want to connect my raspberry pi to wi-fi and this wi-fi uses ip address. I use raspberry pi model 2 (B+), I have wi-fi dongle. How do I connect? I have connected to pi using ssh, and I'm only able to access the command line of pi and don't have access to it's GUI.
EDIT::
>> cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
The Raspberry Pi Foundation has a guide on setting up WiFi without a GUI.
To summarize:
Use the following to scan for available WiFi networks:
sudo iwlist wlan0 scan
This will bring up a list of available networks, make a note of the ssid of your network. Then open and edit the wpa-supplicant configuration file with:
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Once open, add the following to the end of the file:
network={
ssid="The ssid"
psk="The router password"
The ssid is the network name you found earlier, the password is the normal WiFi password. You may need to reboot.
You can check that this is running:
ifconfig wlan0
There should be an IP address under inet addr.
Deleuze
  • 236
