I already tried How do I set up networking/WiFi/Static IP but without success.
The IP address I would like to assign the pi would be 10.0.0.5. This worked well and at the time I am connected to it via SSH. But unfortunately I can not resolve any hostnames.
E.g. ping www.google.com results in unknown host but ping 8.8.8.8 works. I also cannot get any packages which is obvious because it cannot resolve the hostnames.
Below is my current /etc/network/interfaces file. The address, netmask and gateway are correct. I also disabled dhcpcd and enabled networking as mentioned in Network Interfaces method at the linked answer. I also tried the dhcpcd method but it is not working either. I am running Raspbian Jessie on it.
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
    address 10.0.0.5
    netmask 255.255.255.0
    gateway 10.0.0.138
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
I cannot find a way to get it working and I am hoping someone could help me to be able to resolve the hostnames again
Nico T
  • 111
You have not defined a DNS-server. You have to manually define that when you are setting a static IP in the /etc/network/interfaces file. If you instead have used to router (or DHCP-server) to assign an IP-address, defining a DNS-server would not be necessary.
Change the following lines:
auto eth0
address 10.0.0.5
gateway 10.0.0.138
to
auto eth0
address 10.0.0.5
gateway 10.0.0.138
dns-nameservers 8.8.8.8 8.8.4.4
where 8.8.8.8 and 8.8.4.4 is the DNS servers (in this case it is googles primary and secondary DNS)
Orphans
  • 242
For anyone who uses this method (like me) by editing /etc/dhcpcd.conf, you should set the DNS servers accordingly:
interface eth0
# your static IP address:
static ip_address=192.168.1.251/24
static routers=192.168.1.1
# CloudFlare DNS servers (faster than Google, and... it's not Google)
static domain_name_servers=1.1.1.1 1.0.0.1
Reboot:
sudo reboot now
And confirm:
cat /etc/resolv.conf
# Generated by resolvconf
# nameserver 1.1.1.1
# nameserver 1.0.0.1
MS Berends
see this video for how to fix wifi instance on Rasbian Jessie 1.3.6 and OctoPi 0.14.0
https://www.youtube.com/watch?v=dZeJb6Jv-9E
From Wheezy to Jessie they changed the way that the wifi instance connects to router using a static ip address... (or something, Im not a developer...)
tyler
