I installed tkinter using the following request: sudo apt-get install python3-tk
When I try to import the module using:
 #!/usr/local/lib/python3.4
 import tkinter as tk
The above two lines resulted in the following error condition (both IDLE and python3 shell)
ImportError: No module named tkinter
Wits end! - Any insight much appreciated. Thx Tankadere
Shan-Desai
  • 1,541
  • 28
Tankadere
I had this same issue and realized I was using the command
python
when instead I should be using this command
python3
If you use 2.7,
import Tkinter # capital T
if you use 3.4,
import tkinter # lowercase t
Try import Tkinter, not import tkinter, because Python is case-sensitive and Tkinter was renamed in latest verisons.
Kerbiter
On Fedora 25, dnf install python3-tkinter.
