I have two questions, that are related. My situation. I have two wifi networks available. Both are registered in wpa_supplicant.conf One has priority 10, another 20.
When I turn on wlan0 it picks 20 first if available, if not - picks 10. If it picks 20, and I then switch AP off, it automatically switches to 10.
Problem #1: When it initially connected to 20 it got new IP (via DHCP) (192.168..) When I switched network 20 and it reconnected to 10 I still have same IP. (192.168..) If connect to 10 first IP is like 10.0....
Problem #2: Is there a way to make it switch to higher priority AP when it still connected to previous one? Automatically.
UPD: More info on setup
OS: standard Debian. WiFi module: "Wi-Pi"
/etc/wpa_supplicant/wpa_supplicant.conf:
update_config=1
network={
        ssid="TereHomikust"
        psk="***"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        auth_alg=OPEN
        priority=10
network={
        ssid="small device"
        psk="***"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        auth_alg=OPEN
        priority=20
/etc/network/interfaces:
auto wlan0
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
iface default inet dhcp
small device network is AP running in Android phone. TereHomikust is my home network. I want ideally for my RPi always be connected to network with highest priority. Since both networks has different IP/mask setup and both provide DHCP service - I want to have appropriate IP when connected to each of those networks.
Currently, when RPi connected to small device with TereHomikust also available and I kill small device it reconnects to TereHomikust but keeps IP that it got from first networks' DHCP.
If you are using Debian rather than Raspbian (which has different networking configuration) the /etc/network/interfaces should contain:-
allow-hotplug wlan0
iface wlan0 inet manual
What you have is not correct for any setup. manual allows external programs to configure IP and wpa-roam allows wpa_supplicant to react to network changes.
I don't know anything which will change from a working network to another, but this should trigger change if the current network becomes unavailable.
