I'm setting up an AirPi using these instructions, but I get an error when I try and start shairport:
pi@raspberrypi ~/shairport $ ./shairport.pl -a AirPi
Can't locate Net/SDP.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at ./shairport.pl line 48.
BEGIN failed--compilation aborted at ./shairport.pl line 48.
I read up that cpan install Net::SDP should fix the problem, but now I get:
pi@raspberrypi ~/shairport $ sudo su
root@raspberrypi:/home/pi/shairport# cpan install Net::SDP
Going to read '/root/.cpan/Metadata'
Database was generated on Tue, 05 Mar 2013 23:41:02 GMT
Running install for module 'Net::SDP'
Running make for N/NJ/NJH/Net-SDP-0.07.tar.gz
Checksum for /root/.cpan/sources/authors/id/N/NJ/NJH/Net-SDP-0.07.tar.gz ok
Uncompressed /root/.cpan/sources/authors/id/N/NJ/NJH/Net-SDP-0.07.tar.gz successfully
Using Tar:/bin/tar xf "Net-SDP-0.07.tar":
Couldn't untar Net-SDP-0.07.tar
Package seems to come without Makefile.PL.
(The test -f "/root/.cpan/build/NJH-yfX4Kv/Makefile.PL" returned false.)
Writing one on our own (setting NAME to NetSDP)
Had problems unarchiving. Please build manually
Running make test
Make had some problems, won't test
Running make install
Make had some problems, won't install
I tried going to /root/.cpan/sources/authors/id/N/NJ/NJH/ and I could manually untar the file, but it didn't seem to help when I re-ran the command.
I looked in This was the auto-generated one./root/.cpan/build/NJH-yfX4Kv/ and I did find a Makefile.PL, and a tarball, and nothing else. Strange.
I'm stuck. What can I do now?
