19
Been having the toughest time over the last week trying to get gst-omx plugin working with gstreamer on the Raspberry PI.
I wonder if anyone here has done it and could show me how?
I've installed wheezy as git://git.collabora.co.uk/git/user/gkiagia/gst-omx0.10-debian.git needs a testing version of gstreamer.
Gstreamer is working fine on the raspberry using the normal plugins, so no hardware acceleration.
Once I install the gst-omx it comes up in the blacklist for gstreamer and I'm completely stuck as my linux knowledge is very limited so debugging is impossible for me.
Oliver Salzburg
  • 1,794
  • 33
user185955
  • 291
Details from Raspberry Pi forum post
Get and install rpi-update if necessary
sudo wget http://goo.gl/1BOfJ -O /usr/bin/rpi-update && sudo chmod +x /usr/bin/rpi-update
sudo apt-get -y install git-core
Upgrade to the latest packages and firmware
sudo apt-get update
sudo apt-get upgrade -y
sudo rpi-update
sudo reboot
Get gst-omx source from the raspberry branch
cd $HOME
git clone -b 0.10 git://anongit.freedesktop.org/gstreamer/gst-omx
Install the Gstreamer packages, and the packages required to build omx
sudo apt-get install -y autoconf gtk-doc-tools libtool
Autogenerate the configure script, configure, make and install gst-omx
cd gst-omx
./autogen.sh --noconfigure
./configure --prefix=/home/pi/omx
make
make install
Set up the gst-omx environment for the pi user
cp  omx/gstomx-raspberry.conf $HOME/omx/lib/gstreamer-0.10/gstomx.conf
cd $HOME
echo -e \\n# Gstreamer environment >> .profile
echo export GST_PLUGIN_PATH=$HOME/omx/lib/gstreamer-0.10/ >> .profile
echo export GST_OMX_CONFIG_DIR=$HOME/omx/lib/gstreamer-0.10/ >> .profile
echo export LD_LIBRARY_PATH=$HOME/omx/lib/gstreamer-0.10/ >> .profile
. ./.profile
Install the GStreamer Tools
sudo apt-get install gstreamer0.10-tools
Verify that gst-omx has been installed correctly.
If it has the following command should show these plug-ins:
> gst-inspect-0.10 | grep omx
openmax  omxmpeg4videodec: OpenMAX MPEG4 Video Decoder
openmax  omxh264dec: OpenMAX H.264 Video Decoder
Problems with omxmpeg plug-ins being blacklisted
There's a conflict with omx and gstreamer-plugins-bad, so the following cleared the blacklisting:
sudo aptitude remove libgstreamer-plugins-bad0.10-0
Enable omxh264enc plugin for hardware h.264 Encoding
This plugin, so far, appears to be broken, but here's how to enable it. Add the following to $GST_OMX_CONFIG_DIR/gstomx.conf
[omxh264enc]
type-name=GstOMXH264Enc
core-name=/opt/vc/lib/libopenmaxil.so
component-name=OMX.broadcom.video_encode
rank=256
in-port-index=200
out-port-index=201
hacks=no-empty-eos-buffer;no-component-role
Unkle George
  • 91
Add this repo line into /etc/apt/sources.list
deb http://vontaene.de/raspbian-updates/ . main
Then simply ....
sudo apt-get update
sudo apt-get install gstreamer1.0
That 3rd party repository is hosted by a member off the Pi forums. They compile the latest versions of the gst-omx project and publish the files there.
You can check if it recognised the Pi's hardware capabilities using this command
gst-inspect-1.0 | grep omx
Piotr Kula
  • 17,336
  • 66
  • 105
As of April 2015 Raspbian repositories include GStreamer 1.2 and the OpenMAX plugins, so the easiest way is ppumkin's answer but without editing /etc/apt/sources.list:
sudo apt-get update
then check with:
M. Rubio-Roy
  • 568
