9
I'm trying to use openbox to customize my raspberry pi 3. Basically, what I want to do is start an openbox session on boot up and have openbox autostart a GUI application. This is what I have so far
in ~/.config/lxsession/LXDE-pi/autostart
I commented out the first 3 lines:
#@lxpanel --profile LXDE-pi
#@pcmanfm --desktop --profile LXDE-pi
#@xscreensaver -no-splash
and added this line:
@openbox-session
This causes openbox to start when I boot up my system. I see a black screen
Following this guide: http://openbox.org/wiki/Help:Autostart It says that
"When you log in with the "Openbox" session type, or launch Openbox with the openbox-session command, the environment script will be executed to set up your environment, and the autostart script can launch any applications you want to run at startup."
so, I edited the autostart file in ~/.config/openbox/autostart in my pi user. (I also tried editing the global file) I put this in the file:
/home/pi/mystartupprogram
On first reboot it worked my GUI starts up which is great but...next reboot I'm back to black screen and I see part of my GUI in the top left corner and all the rest is black.
unconditionalcoder
  • 213
This is the simple answer: sudo update-alternatives --config x-session-manager One can just run this and select the openbox-session then the next restart will get you the openbox window manager. No need for hacking files etc.
David Savage
  • 151
I had the same problem. I post it for any future googlers.
  1. Disable Desktop autologin
    Run sudo raspi-config and navigate to 3 Boot Options / B1 Desktop / Cliand choose B2 Console Autologin
  2. Run startx in rc.local
    Open rc.local with sudo nano /etc/rc.local. At the end, before exit 0 add startx &
  3. Configure xinitrc
    sudo nano /etc/X11/xinit/xinitrc
    Comment this line
    . /etc/X11/xsession
    Add this line to start openbox
    exec openbox-session
  4. Run your programs with autostart
    sudo nano /etc/xdg/openbox/autostart
    Add your commands
    /path/to/program &
    Important: End all commands with &
VoilĂ , you have now an Raspberry Pi that automatically boots to Openbox and autostarts your applications
I found this to be useful
install the rpi lite version then:
sudo apt install lightdm openbox
lightdm = login manager, just use raspi-config to select autologin gui
openbox = gui to run your app
you can use a tty for command line to setup your app to auto start:
example:
mkdir ~/.config/autostart
nano ~/.config/autostart/my_app.desktop
in nano:
[Desktop Entry]
Type=Application
Exec=/path/to/my/app <-best to use full path ex: /home/pi/bin/my_app
Shimon S
  • 101
