A question came up recently which requires the generation of a unique identifier for the Pi using Win-Iot/C#. My first thought was to use a MAC code, but the approach that I've found at embedded101.com looks pretty cumbersome.
Is there a neat UUID-type identifier available for the Pi under Windows IoT, and how do I access it?
goobering
  • 10,750
  • 40
  • 64
If all you want to rely on is the MAC address of an interface you can use this code. It has been available since .NET 2 and it should be implemented in IoT and Mono alike
public static HashSet<string> NetworkIds()
  var result = new HashSet<string>();
  var networkProfiles = Windows.Networking.Connectivity.NetworkInformation.GetConnectionProfiles().ToList();
  foreach (var net in networkProfiles)
    result.Add(net.NetworkAdapter.NetworkAdapterId.ToString());
  return result;
You can also go and explore this namespace on the IoT
import Windows.Security.ExchangeActiveSyncProvisioning;
and try checking what lies on these object. Try and test them on two Pi's
var deviceInfo = new EasClientDeviceInformation;
deviceInfo.
Here is another, more complete sample that may be usefull.
using System;
using Windows.Security.ExchangeActiveSyncProvisioning;
using Windows.System.Profile;
    public sealed class DeviceInfo
        private static DeviceInfo _Instance;
        public static DeviceInfo Instance
            get {
                if (_Instance == null)
                    _Instance = new DeviceInfo();
                return _Instance; }
        public string Id { get; private set; }
        public string Model { get; private set; }
        public string Manufracturer { get; private set; }
        public string Name { get; private set; }
        public static string OSName { get; set; }
        private DeviceInfo()
            Id = GetId();
            var deviceInformation = new EasClientDeviceInformation();
            Model = deviceInformation.SystemProductName;
            Manufracturer = deviceInformation.SystemManufacturer;
            Name = deviceInformation.FriendlyName;
            OSName = deviceInformation.OperatingSystem;
        private static string GetId()
            if (Windows.Foundation.Metadata.ApiInformation.IsTypePresent("Windows.System.Profile.HardwareIdentification"))
                var token = HardwareIdentification.GetPackageSpecificToken(null);
                var hardwareId = token.Id;
                var dataReader = Windows.Storage.Streams.DataReader.FromBuffer(hardwareId);
                byte[] bytes = new byte[hardwareId.Length];
                dataReader.ReadBytes(bytes);
                return BitConverter.ToString(bytes).Replace("-", "");
            throw new Exception("NO API FOR DEVICE ID PRESENT!");
Piotr Kula
  • 17,336
  • 66
  • 105
Here in .NET, easy peasy:
string path = "/sys/firmware/devicetree/base/serial-number";
string id = File.ReadAllText(path);
