I want to make a file executable, but I don't know how to do that and have the idle prompt appear afterward. Is the best way to just open idle and then import the file? I'm using python3 on raspbian jessie. Can you add flags like -i when you make the file executable? Please help.
Update I found that adding the -i flag in the beginning of the file works.
jath03
  • 436
  1. Keep all your executable files in a folder, I usually keep it in /home/pi/. Your folder can be called for example exec
    mkdir exec
  2. move your Python3 script into this folder:
    mv myScript.py ~/exec/
  3. In your myScript.py add the shebang line on the top-most part of script
    $ nano myScript.py
    ## add this line on top of file
    !/usr/bin/python3
CTRL+O then press Enter and in the end CTRL+X
  1. give executable rights to your file:
    $ chmod +x myScript.py
Additional : you can also remove the .py from the file and keep it just myScript
    mv myScript.py myScript
You have your script as an executable you can trigger it by doing a simple
   ./myScript
Pausing Scripts
I think this is inherent to the script you have written, you can use time.sleep in your script to pause the working and do something in the meantime for e.g. print something or do nothing.
Adding Arguments
You can use configParser module in Python to give arguments to your script
Your executable will now run as:
./myScript -arg1 -arg2
Links
Python3 ConfigParser
time.sleep() for Pausing Python scripts
Edit:
Parse Flags to a Python Executable
Shan-Desai
  • 1,541
  • 28
I am running python 3.7.3 on a Raspberry Pi 3. I found that I needed to change the line at the top of the file from
!/usr/bin/python3
to
#!/usr/bin/python3
in order to get it to work.
Mats Karlsson
  • 979
