12
Is it possible to get an IP address over DHCP but force a DNS server instead of using the ones from the DHCP?
I should be able to do so with a static IP addresses, but I would like to know how to do it getting an IP address over DHCP. I thought that changing /etc/resolv.conf would be permanent, but it dismisses the changes after a reboot.
Peter Mortensen
  • 2,004
Albert Vonpupp
  • 310
5 Answers5
9
The only thing that worked for me was:
Edit /etc/dhcp/dhclient.conf and un-comment the line:
prepend domain-name-servers 208.67.222.222;
Anyway thanks for your for your help!
Albert Vonpupp
  • 310
dns-nameservers (and all others dns-xxx directives in /etc/network/interfaces) does not work in raspbian out of the box, since resolvconf is not installed by default.
sudo apt-get install resolvconf solves the issue.
Stefano Terna
I fixed this following the steps from cuonglm's answer on Unix & Linux Stack Exchange.
Edit the file /etc/dhcp/dhclient.conf and add
supersede domain-name-servers 8.8.8.8, 8.8.4.4;
Then restart network or run dhclient to make changes.
From man dhclient.conf:
The supersede statement
   supersede [ option declaration ];
   If for some option the client should always  use  a  locally-configured
   value  or  values rather than whatever is supplied by the server, these
   values can be defined in the supersede statement.
Aurora0001
  • 6,357
  • 25
  • 39
Apekatten
You can define them with a line in /etc/network/interfaces.
Underneath your interface, add the following line, replacing the x's with the actual IP of the DNS server:
dns-nameservers xxx.xxx.xxx.xxx
nc4pk
  • 1,378
  • 25
It's an old threat, but for current Raspbian/Debian you have to add at the end of /etc/dhcpcd.conf:
static domain_name_servers=1.1.1.1 8.8.4.4
