I made Bash script what running fan for cooling. PIN20 is PWM out and this script work perfect. I run this script over therminal arroun 15 hours.
Afer all tests i register script for autoload after reboot like this:
$ sudo cp rpipwm.sh /etc/init.d/rpipwm.sh
$ sudo chmod +x /etc/init.d/rpipwm.sh
$ sudo update-rc.d /etc/init.d/rpipwm.sh defaults
After last line I get this error: update-rc.d: error: initscript does not exist: /etc/init.d//etc/init.d/rpipwm.sh
After that error I update with this:
$ sudo update-rc.d rpipwm.sh defaults
And reboot.
After reboot my script start to work and all is fine arround 20min. After that time my script stop to work. If I run this manualy on terminal script can work hours and hours with no errors.
What's mistake?
Here is my script.
#!/bin/bash
### BEGIN INIT INFO
# Provides: rpipwm
# Required-Start: $local_fs
# Required-Stop: $local_fs
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: rpipwm
### END INIT INFO
FLAG="/var/log/rpipwm.log"
if [ ! -f $FLAG ] ;
then
a="echo 20 > /sys/class/gpio/unexport;"
a=$a"echo 20 > /sys/class/gpio/export;"
a=$a"echo out > /sys/class/gpio/gpio20/direction" || true
eval $a
#start loop script
i="0"
temp="0"
while true;
do
i=$(($i+1))
#Read temp
if [[ $(bc <<< "$i > 10") == 1 ]] ;
then
cpuTemp0=$(cat /sys/class/thermal/thermal_zone0/temp)
cpuTemp1=$(($cpuTemp0/1000))
## cpuTemp2=$(($cpuTemp0/100))
temp=$cpuTemp1
i="0"
fi
a=""
#If temperature is equal or lower than 39.99, the fan will stop spinning
if [[ $(bc <<< "$temp < 39") == 1 ]] ;
then
a=$a"echo 0 > /sys/class/gpio/gpio20/value"
fi
#If temperature is between 40 and 42.99, the fan will start with 1 second burst and 1 second sleep
if [[ $(bc <<< "$temp >= 40 && $temp <= 44") == 1 ]] ;
then
a=$a"echo 1 > /sys/class/gpio/gpio20/value; sleep 0.5; echo 0 > /sys/class/gpio/gpio20/value; sleep 0.1 "
fi
#If temperature is between 43 and 47.99, the fan will start with 1 second burst and 0.5 second sleep
if [[ $(bc <<< "$temp >= 45 && $temp <= 49") == 1 ]] ;
then
a=$a"echo 1 > /sys/class/gpio/gpio20/value; sleep 1; echo 0 > /sys/class/gpio/gpio20/value; sleep 0.5"
fi
#If temperature is equal or higher than 48, the fan will start spinning constantly
if [[ $(bc <<< "$temp > 50") == 1 ]] ;
then
a=$a"echo 1 > /sys/class/gpio/gpio20/value"
fi
eval $a
sleep 0.1
done
touch $FLAG
fi
UPDATE
I reorder script, put log in script and now have all to work properly and with no unexpected stop or break.
#!/bin/bash
### BEGIN INIT INFO
# Provides: rpipwm
### END INIT INFO
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/home/wc3/palert
if [ ! -f $FLAG ] ;
then
eval $a
#start loop script
i="0"
temp="100"
while true;
do
i=$(($i+1))
#Read temp
if [[ $(bc <<< "$i > 5") == 1 ]] ;
then
temp=$cpuTemp1
i="0"
fi
a=""
if [[ $(bc <<< "$temp <= 39") == 1 ]] ;
then
fi
then
fi
if [[ $(bc <<< "$temp >= 45 && $temp <= 47") == 1 ]] ;
then
fi
if [[ $(bc <<< "$temp >= 48") == 1 ]] ;
then
fi
eval $a
sleep 0.1
done
touch $FLAG
fi
) &> /home/pi/rpipwm.txt
