39
I've got a python script that uses sys.platform.startswith('linux') to test if it is on linux or not, but then I can't tell the difference between the x86/64 processor, and the raspberry pi's ARM processor.
The reason I need this, is to run an external script that's compiled for either mac, linux x86/64, or linux ARM for the raspberry pi.
From what I can tell, there's not really a unified way to tell that you are in fact running on a raspberry pi. Any help would be appreciated.
jnesselr
  • 493
10 Answers10
22
You can use Python's os module to obtain this information through uname:
import os
os.uname()
This function should provide platform and other information on most Linux or Unix-like distributions.
From the Python documentation:
os.uname()
Return a 5-tuple containing information identifying the current operating system. The tuple contains five strings: (sysname, nodename, release, version, machine). Some systems truncate the nodename to eight characters or to the leading component; a better way to get the hostname is socket.gethostname() or even socket.gethostbyaddr(socket.gethostname()).
Availability: recent flavors of Unix.
milancurcic
  • 626
I found you can get the Pi model and version from:
/sys/firmware/devicetree/base/model
Ex: Raspberry Pi 3 Model B Rev 1.2
I have a shell script to look for this and return the contents if it exists. An OS call to read the file if it exists should set you right. The premise is, if it doesn't exist, its definitely not a RPi. If it does, then inspect the content to be sure.
Wesley Mason
  • 171
Here is a simplified version of @Artur Barseghyan's answer
import io
import os
def is_raspberrypi(): if os.name != 'posix': return False chips = ('BCM2708','BCM2709','BCM2711','BCM2835','BCM2836') try: with io.open('/proc/cpuinfo', 'r') as cpuinfo: for line in cpuinfo: if line.startswith('Hardware'): _, value = line.strip().split(':', 1) value = value.strip() if value in chips: return True except Exception: pass return False
Or for an even leaner solution as suggested by @Dougie without the need to maintain an updated list of chipsets.
    try:
        with io.open('/sys/firmware/devicetree/base/model', 'r') as m:
            if 'raspberry pi' in m.read().lower(): return True
    return False
Chris
  • 263
platform.machine() will return:
  • armv7l on Raspberry Pi running on Raspbian 32-bit.
  • aarch64 on all Arm 64-bit OSes, including those running in Amazon AWS Graviton2.
So this is a more reliable way of detecting Arm, if your program is written for Arm, instead of Raspberry Pi specifically.
Hendy Irawan
  • 161
This is more of a problem with the advent of the Pi 2 (which is not simple to distinguish from the Beaglebone Black). The highest level of detail is found in /proc/cpuinfo on Linux-based systems (the 'Hardware' line). Here's an example of parsing that, from the Adafruit GPIO code:
https://github.com/adafruit/Adafruit_Python_GPIO/blob/master/Adafruit_GPIO/Platform.py
The best widely-applicable system-identifying information I have found has been with:
platform._syscmd_uname('-a')
This appears to give the same output as the shell command uname -a. In most cases the returned output is essentially the same (a string instead of a 5-tuple) as that of os.uname().
The ones I've tested and found equivalent outputs are OSX 10.9.5, Ubuntu 14.04, and Raspbian (??) Wheezy. On a Synology NAS, though, I get more information from the platform._syscmd_uname('-a') version:
>>> os.uname()
('Linux', [hostname], '3.10.35', [...], 'x86_64')
'Linux [hostname] 3.10.35 [...] x86_64 GNU/Linux synology_cedarview_1813+'
Seeing "synology" in the output there identifies it as an environment where things behave unexpectedly.
I've used this simple function previously:
from pathlib import Path
import re
CPUINFO_PATH = Path("/proc/cpuinfo")
def is_raspberry_pi(): if not CPUINFO_PATH.exists(): return False with open(CPUINFO_PATH) as f: cpuinfo = f.read() return re.search(r"^Model\s:\sRaspberry Pi", cpuinfo, flags=re.M) is not None
It just checks that the /proc/cpuinfo file exists, and then checks if there is a Model line that matches Raspberry Pi.
It might not be completely generic, but it does not rely on BCM-processor being used exclusively for Raspberry Pi:s, nor arm, so it should give very few false positives, but possibly risks to return some false negatives in case Raspberry Pi OS changes the cpuinfo.
Tested on Raspberry Pi 4 and Raspberry Pi 3B.
Better way of doing this (Python code snippet):
import io
def is_raspberry_pi(raise_on_errors=False): """Checks if Raspberry PI.
:return:
try:
        found = False
                found = True
                label, value = line.strip().split(':', 1)
                if value not in (
                    'BCM2708',
                    'BCM2709',
                    'BCM2711',
                    'BCM2835',
                    'BCM2836'
                    if raise_on_errors:
                        raise ValueError(
                            'This system does not appear to be a '
                            'Raspberry Pi.'
                    else:
                        return False
        if not found:
            if raise_on_errors:
                raise ValueError(
                    'Unable to determine if this system is a Raspberry Pi.'
            else:
                return False
except IOError:
    if raise_on_errors:
        raise ValueError('Unable to open `/proc/cpuinfo`.')
    else:
        return False
return True
IS_RASPBERRY_PI = is_raspberry_pi()
David
  • 723
  • 22
You can simply check if the file /etc/rpi-issue exists with pathlib.
IS_RPI = Path("/etc/rpi-issue").exists()
I know the file can be created easily but every raspberyOS and Raspbian has that file.
MatsK
  • 2,882
  • 22
ensarman
  • 111
On PI 3
import os
os.uname()[1] == 'raspberrypi'
Because:
uname -a
Linux raspberrypi 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
