I am trying to learn about Yocto Project on my Raspberry Pi3 board. I have followed the steps mentioned in this link to build the Yocto image.
I am behind a firewall, so I have changed the git.py file to use https instead of git. To be precise I have done below changes
Change 1:
if 'protocol' in ud.parm:
ud.proto = ud.parm['protocol']
elif not ud.host:
ud.proto = 'file'
else:
#ud.proto = "git"
ud.proto = "http"
Change 2:
repourl = "https://%s%s%s" % (username, ud.host, ud.path)
I am able to build successfully and have extracted the image on to the SD card as instructed in the link. But after loading the SD card on my Pi board, it is stuck in the initial screen (rainbow screen) and I don't see any logs coming on the serial console.
I have also tried by changing machine variable in the conf/local.conf file as mentioned below:
MACHINE ?= "raspberrypi2"
Am not sure what am missing, any help will be appreciated. Thanks.
