I'm new at the Raspi 3 and unix in general, and now trying to build a headless streaming application, and trying to automate some basic setup steps on boot.
If I want to guarantee the fastest connection speed is used for streaming, I'm just wondering if there's any benefit to turning off wlan0 if I see they're connected to eth0 already.
I guess my question is what happens when both wired and wireless connections to Internet exist? Do the connections get prioritized for speed, or do they get pooled together - or is there a possibility that the wireless would be used instead of wired ethernet?
I realize the answer might apply to all Unix flavors - and possible even Windows - but I'm specifically interested in Raspbian
dbmitch
  • 401
  • 22
Normally if both Ethernet and Wifi are capable of supplying an internet connection to the Raspberry Pi the one with the lowest metric (independent of the internet speed) will be the one used by the Pi to get the internet (In my personal experience eth0 always gets the lowest metric). If you want to check the metrics type route -n you would see something like :
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         100.100.100.1   0.0.0.0         UG    202    0        0 eth0
0.0.0.0         192.168.137.1   0.0.0.0         UG    303    0        0 wlan0
100.100.100.0   0.0.0.0         255.255.255.0   U     202    0        0 eth0
192.168.137.0   0.0.0.0         255.255.255.0   U     303    0        0 wlan0
In this chart you can see that eth0 has the lowest metric so the internet coming from that connection will be the one used. If you wanted to change the metric so that wlan0 becomes the one with the lowest metric then type
sudo route delete  default gateway 192.168.137.1
and then
sudo route add  default gateway 192.168.137.1
you will see that the chart is now
0.0.0.0         192.168.137.1   0.0.0.0         UG    0      0        0 wlan0
and the internet coming from wlan0 will be the one used
Victor
  • 480
