I have spent the day trying to port the Adafruit UV Sensor Library (Link) from Arduino to Python and SMBUS and am definitely making progress. The data sheet is a bit vague on detail compared to the HDC1008 sensor about how to read but am hoping that someone with a better understanding of C++ and SMBUS/i2c might be able to double check my assumptions and explain why I'm getting slightly different values than those seen on the Arduino.
Current outputs are Pi Vs Arduino:
  • Vis:350 Vs 266
  • IR: 941 Vs 304
  • UV: 0.46 Vs 0.05
The whole class is a bit long so I am linking to it here - bad I know. The two functions I'm most unsure of are when the UV sensor is enabled (C++ lines are commented):
    """uint8_t Adafruit_SI1145::writeParam(uint8_t p, uint8_t v) {"""
    def writeParam(self,p,v):
            #Serial.print("Param 0x"); Serial.print(p, HEX);
            #print("Param 0x",p,"HEX")
            #Serial.print(" = 0x"); Serial.println(v, HEX);
            #print("= 0x",v,"HEX")
            #write8(SI1145_REG_PARAMWR, v);
            self.bus.write_byte_data(self.SI1145_ADDR, self.SI1145_REG_PARAMWR, v)
            #write8(SI1145_REG_COMMAND, p | SI1145_PARAM_SET);
            self.bus.write_byte_data(self.SI1145_ADDR, self.SI1145_REG_COMMAND, p | self.SI1145_PARAM_SET)
            #return read8(SI1145_REG_PARAMRD);
            return self.bus.read_byte_data(self.SI1145_ADDR, self.SI1145_REG_PARAMRD)
and reading 16 bits for each of the different light types (I thought it was only 7!) e.g
    """returns the UV index * 100 (divide by 100 to get the index)"""
    """uint16_t Adafruit_SI1145::readUV(void) {"""
    def readUV(self):
            #return read16(0x2C);
            raw = float(self.read16(0x2C)) / 100.00
            return raw
Here is the method:
    """Read method used to read 16 bits"""
    """uint16_t Adafruit_SI1145::read16(uint8_t a) {"""
    def read16(self,reg):
            #Wire.beginTransmission(_addr); // start transmission to device
            #Wire.write(a); // sends register address to read from
            #Wire.endTransmission(); // end transmission
            self.bus.write_byte(self.SI1145_ADDR, reg)
            time.sleep(0.015)
            #Wire.requestFrom(_addr, (uint8_t)2);// send data n-bytes read
            #ret = Wire.read(); // receive DATA
            ret = self.bus.read_byte(self.SI1145_ADDR)
            #ret |= (uint16_t)Wire.read() << 8; // receive DATA
            ret |= self.bus.read_byte(self.SI1145_ADDR) << 8
            return ret
Byte Insight
  • 246
This is the python code for Si132 python library and with little modification you should be able to make it work for SI1145. if you still face any issue you can post this on CE I2C community they have all kinds of I2C libraries.
bruce
  • 461
