I installed Raspbian on my RaspPi 3. Downloaded Jessie version of Kivy.
However, when I open 'showcase' or '3D monkey Demo' or 'Hello tutorial', the example shows but it wont close out .
The keyboard or mouse doesn't respond or interact with the application. I searched on other StackExchange q's but it only deals with RaspPi2 or lower problems.
How do I make my mouse and keyboard to interact with the application?
Help please…
You can do that in 2 ways
  1. Refer the link http://www.modmypi.com/blog/boot-to-command-line-raspbian-jessie
  2. You can go to sudo raspi-config and go the Enable Boot to Desktop/Scratch and select the option that boots to command line.
GPU can be set either through raspi-config or in config.txt file.
sudo raspi-config - > Advanced Options -> Memory Split and then set your value there.
gpu_mem_1024=512
I have set this value as 128 since I don't use GUI at all. The optimal value I suggest if use GUI is 512 otherwise it will be sluggish.
Also I had some issues with KeyBoard configurations which I resolved by selecting appropriate keyboard from
sudo raspi-config -> Advanced Options - > configure-keyboard
Hope this helps.
Varad A G
  • 850
