I am having the following situation:
On an embedded linux board (a Raspberry Pi - but might be replaced in future by a SBC with similar h/w-specs) a Python application is reading sensor data every five seconds.
I want to extend the application by some long-term monitoring which can be accessed through a web-interface showing the long-term activity nicely with graphs, etc.
After doing some research I ended up with a couple of possible databases:
  • MySQL
  • SQLite
  • RRD-Tool
I am however a bit afraid of using one of the above databases on a Raspberry Pi. The reasons are the following:
  1. Data will be stored for one or two years. With having new data every 5 seconds this will make a total of more than 6 million entries! - For a single year only.
  2. I am not sure if the Raspberry Pi (or similar devices) will handle MySQL or SQLite databases of that size.
One solution might be lowering the resolution like you'll find it build-in when using the RRD-Tool as the database. But due to the fact that the RRD-Tool works with a concept of hearbeat and step, data will be averaged every time a new entry is being inserted into the database. And I haven't figured out how to turn that off.
So which database is best for:
  • Millions of entries
  • Or: lowering resolution after given time but without building averages, etc.
  • Working fluently on Raspberry (similar devices) when accessing over Web-Interface an 2-3 Users in parallel
Raspberry is used for:
  • Reading the sensors data
  • storing it into a database
  • providing web-interface to visualize data
Simon Kemper
  • 193
"Millions of entries" is peanuts for databases (or even data files as @joan suggests) nowadays. Let's say you need to store a 64-byte datavalue (maybe readings from a few sensors). If you store that a million times, you've used up 64MB of space. Even the RPi doesn't think twice about that file size. And sorting through 1M records is a breeze for any proper db. Once you start getting in the billions of records in several tables with complex joins - then your database choice might play a role. Until then - use whatever you like. MySQL is straightforward and well supported
Phil B.
  • 5,053
  • 30
