What methods are available for people to use to view images on the command line? I tried the accepted answer here but i got the error bash: fbi: command not found so I'm not quite sure what the problem is. I also tried this (first duck-duck-go result) but it gave me this when trying to install:
pi@raspberrypi:~ $ sudo apt-get install -y fim
Reading package lists... Done
Building dependency tree
E: Unable to locate package fim
So how can i view images on the command line without the GUI?
This question has been marked as a duplicate of this question and i will admit that they are extremely similar however at the bottom of every question that has been closed as a duplicate (first result for duplicate:yes here) it says:
marked as duplicate by lenik, syb0rg, RPi Awesomeness, Impulss, Butters Mar 3 '14 at 20:12
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
I take that to mean if i see a question that is similar to my question but the answers do not work which is the case here i should ask a new one. therefore i do not believe that this should be closed.
sir_ian
  • 980
  • 38
gpicview is a fast and simple image viewer.try this, navigate to the working directory, then type the following command.
I use FBI, because FIM is no longer in the repository. You can install it with the command apt-get install fbi.
Jacobm001
  • 11,904
  • 47
  • 58
