I am trying to install a driver for a wireless adapter I have.
I am using amped-wireless-aca1-linux driver on github.
Hoping it should work on a raspberry pi as well.
I get the following error when trying to build it
make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.4.13-v7+/build     M=/home/pi/rtl8812au  modules
make[1]: *** /lib/modules/4.4.13-v7+/build: No such file or directory.      Stop.
Makefile:1052: recipe for target 'modules' failed
make: *** [modules] Error 2
I figured, oh, maybe some part of the raspberry pi doesn't make this compatible. So, I then tried rtl8812au driver. Same error. Even with the flag active here
I am not sure how I suppose to build the specific module for the wireless adapter. I have done update, upgrade and rpi-update
The directory of /lib/modules/4.4.13-v7+/ contains
kernel/ modules.alias.bin modules.builtin.bin modules.dep.bin modules.order modules.symbols modules.alias modules.builtin modules.dep modules.devname modules.softdep modules.symbols.bin
It is obviously looking for a build directory, but in the /lib/modules/4.4.13-v7+/ there is no indication one can be built. So, either something needs to be added or it is done elsewhere independently.
  • sorry not enough rep for links.
DKJ
5 Answers5
To build this module from source, I did the following on my RPI2.
Install build tools:
# apt install build-essential bc git wget
Get kernel source code
# cd /usr/src
# git clone --depth 1 https://github.com/raspberrypi/linux.git
# ln -s linux $(uname -r)
# ln -s /usr/src/linux /lib/modules/$(uname -r)/build
Prepare linux build headers
# cd linux
# wget -O Module.symvers https://raw.githubusercontent.com/raspberrypi/firmware/master/extra/Module7.symvers
# KERNEL=kernel7
# make bcm2709_defconfig
# make prepare
# make modules_prepare
Download driver and build, (replace the module with the one you want build)
# cd ~
# git clone https://github.com/gnab/rtl8812au.git
# cd rtl8812au
# KERNEL=kernel7
# make
Install
# make install
NOTE: the above should work for RPI2/3, check here for the KERNEL and Module.symvers file. BTW: I've build this ko on RPI2 on 4.4.13-v7+, you can download it from my dropbox
Mayli
  • 156
I have followed this and a few other pages to install the usb wifi device (RTL8821AU/RTL8812AU) - the right method is documented by MrEngman on https://www.raspberrypi.org/forums/viewtopic.php?f=66&t=66499&start=175. Go all the way to page 8 for the correct link since the dropbox link expired. I pasted the steps below. It takes 1 minutes to see wifi alive (ifconfig), whereas all other solutions consumed me 2+ days in vain (ex : installing many packages and updating all the libraries). My USB has ID 0bda:a811 Realtek Semiconductor Corp with > lsusb command.
  1. sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
  2. sudo chmod +x /usr/bin/install-wifi
  3. sudo install-wifi -h (remove -h to run the installation)
VictorL
  • 111
That procedure works for me.
1) Update your raspberry pi
sudo apt full-upgrade
2) Restart your system
sudo reboot
3) Get the firmware from this repo
sudo git clone https://github.com/gnab/rtl8812au.git
4)Modify the Make file according to with your system
sudo nano Makefile
CONFIG_PLATFORM_I386_PC = n
CONFIG_PLATFORM_ARM_RPI = y
5) Compile
sudo make
6) Installing
sudo cp 8812au.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
In Makefile you must edit line:
CONFIG_PLATFORM_ARM_RPI = n
to:
and
CONFIG_PLATFORM_I386_PC = y
to:
This will enable configuration for Raspberry Pi. Also you need to install kernel-headers:
sudo apt-get install raspberrypi-kernel-headers
Huczu
  • 1,251
Does the driver have a cmake? .It may have cmakelist file. Try this, create a build directory then on command prompt go to the build directory and type "cmake .." without the quotes. Then type make.
